An Excellent Video Guide on How to Configure PBO/Curve Optimizer
22 May 2015
Manchester
What method did you use? I might have another go at it, just don’t fancy spending ages. What is 155a EDC?
Just tested each core in - 5 steps each time and started at 170a EDC, EDC is in with all the other settings but there's an auto setting that needs to be set to manual to reveal the EDC parameters that you need to change. Really simple. I probably have a good chip but I would expect most of them to be capable of doing something with these settings.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Did you follow a guide, if so link? What were the 5 steps? How long did it take total? Thanks :)
23 Jun 2021
England
Can be better. This 5900x scores 22,000 with tweaking so I'd look into PBO and CO.
This one is stable at - 30 on all cores with Curve Optimiser and 155a EDC. Boosts to almost 5Ghz in games while staying fairly cool, the extra performance is noticeable.
Watch the video posted in the first post here. I didn't use that particular one but it's not so difficult.
Edit: it IS normal without tweaking.
Thing is, as soon as i flip on PBO, bam 28.5k+ multi score
23 Jun 2021
England
But that's an all core load so to be expected IMHO. What are you using the PC for? If just gaming I'd enable PBO and just game on it.
In terms of your cooling, that looks good. Maybe make the top 2 side fans exhausts as you only have one fan exhausting warm air out of the case.
yeah don't forget the top aio is exhausting as well so it's kinda neutral airflow
TNA
TNA
Caporegime
13 Mar 2008
Greater London
22 May 2015
Manchester
Thanks man. Will watch that and also the video in the OP and have a little mess about when I fancy. Can make a profile in BIOS and if any issues can just go back to what I have now which is essentially PBO off which runs nice and cool and boosts up to 4.9Ghz in games.
If you have 4.9Ghz boost in games that'd do me personally. This one goes to 4.7/4.8 and very occasionally but briefly 4.9 when gaming, but lowering the EDC means that an all core load goes to around 4.6 and stays very cool on this one. I don't mind that, it's not a super realistic use scenario for most people if you're just gaming. And if your BIOS allows you to save profiles then sure, you could do that.
