Surely everyone does this? I’d add shake it over the banister to the list as well.The method my wife was taught in Germany many years ago when she worked in a Hotel was to:
- lie the duvet flat on the bed, folded in half so you can easily reach the corners
- turn the cover inside-out
- reach inside the cover to the corners and then grab the duvet corners
- shake the cover over the duvet
You need the height to be able to shake it down and the arm span when its a double.
Iron a duvet cover........I've never done it this way. I'm tall enough and with a long enough arm span that i can sort of thread the duvet into the cover, then grab both corners and shake it down to the other end. Button up, and then shake the corners a bit to get it aligned.
I can see how that method would make it easier though. I assume people who use this method must iron their duvet covers inside out?
Almost half of single men said they don't wash their bed sheets for up to four months at a time, with 12% admitting they wash them when they remember - which could be even longer.
Single women changed more often, 62% cleaning their bedding every two weeks, and couples claiming to do theirs every three weeks, according to data from a bedding company.
I do it like this. Is there any other way?The method my wife was taught in Germany many years ago when she worked in a Hotel was to:
Longer than once a week is rank in my books. Grim reading.![]()
How often should you change your bed sheets?
A new survey has found almost half of single men said they wash their bed sheets every four months.www.bbc.co.uk
