Quick cabling question.. I plugged in the ones from the case except two.
I have a usb3.0 plug from the case (blue) that I cant find a home forAlsoa case push cable for RGB but I assume thats lights but I am no bothered about them.
So I plugged in the CPU fan, GPU to the PSU and MB plug to.. is there anything else that needs to plug in except the mystery blue USB cable?
Well I turned it on. Case fans are on, MB has a white light on, GPU fans are on but no pic on the monitor. Any ideas?
I tried re-seating the RAM, CPU power cable. Tried a new HD cable.
I am loathe to try re-seating the GPU as it was a hassle to fit in.
I am not sure if I am meant to be hearing anything more than the sound of the fans? LIke 'loading noises'?
Just noticed the light I can see is the CPU warning light. WIll look at it tomorrow.
Yes it is the 5500. I am using the cooler that came with it.Is it a 5500? It is possible that the BIOS doesn't support this CPU, but my understanding was that unrecognised CPUs (the 5500, 5600 non-x and 5700X) would still boot on an unsupported bios. Most B550 boards have BIOS flashback without a supported CPU (if this is the problem), but I would not try flashing until you have exhausted all other options.
What cooler are you using? Overtightening the cooler can sometimes cause problems.
UPDATE: Flashback worked. I now have a image on my screen!
Now its the BIOS light that is lit.. does it ever end![]()
Not that I can see.. has it? The Wifi one was an extra £100.. so I am happy to only pay £40 for a wifi & bluetooth adapterOk good it is all working. With all the issues you at least know you can fix the thing if you have problems in the future.
Wifi adapter ? doesnt the mobo have built in wifi ?
Have you set the memory speed in the bios usually done with xmp profile ?I bought the wrong mother board, basically, it was my mistake! Its worked out around the same price though so its fine.
Hmm no, I havent..?Have you set the memory speed in the bios usually done with xmp profile ?
