It's just a shame this reputation was from over 10 years agoTrue but rightly or wrongly, AMD has a worse reputation for driver problems. It's good that they're turning this around though.
That depends, if you're pro-AMD, it's been fixed for ages. If you're pro-nVidia, it still exists.When will the 'AMD Driver issues' myth disappear?
ive been running Radeon cards for near on 10yrs and had one issue whereby Chrome would stutter its nuts off and thats it.
It's just a shame this reputation was from over 10 years ago![]()
I had to reinstall Windows 7 multiple times and revert back 5/6 previous driver releases to get the AMD control panel the load sucessfully on a fully patched Windows 7 install as their final release driver for Windows 7 was broken. Oh and when the control panel crashes sometimes just changing options everything resets to default so you have to change all the settings back as the AMD software tries to download and auto install itself to the latest driver version which does not work.
As much a people dunk on nVidia's Windows 95 style control panel I've never had any issue with it.
I dont know what worse the bad times when people have issues with AMD drivers or the obnoxious AMD fans that deny, blame and gaslight people into thinking its their fault.
I had driver issues with my R9-270x and my RX580, not sure how long ago they came out, but you could install the base driver, then anytime you wanted to do an update it just wouldn't take it, I've never had any issues with Nvidia drivers and I certainly wouldn't call myself a fan boy...
Their financials would suggest other wise.Which is why they're struggling to sell GPUs compared to Nvidia.
Are there any reviews of 2x 6950XT in crossfire yet?
Of course they are still workingget back to those 7990 crossfire benches... They still working ?
nice.. I miss themOf course they are still working![]()
