Don
- 20 Oct 2002
- Oxfordshire / Bucks
theres a Q2 up for sale in MM under £200 ...
Yep, with an aftermarket headstrp too, albeit one of the cheaper ones, still looks like it'll do a good job though.theres a Q2 up for sale in MM under £200 ...
Well my Reverb G2 arrived this morning. What an awful, awful headset. Absolutely crap, so it's being returned.
Spent 2hrs messing about with mixed reality and steamvr getting nowhere. Just can't see the desktop, nor play any games. Hell, can't even move around in steamvr lol When the headsets on, my monitors switch off haha No idea what the controls are, but they aren't keyboard/mouse, xbox controller or the HP controllers. Telepathy?
Watched no end of youtube videos, says it's easy just go into settings....where?
I can see why Meta aren't interested in PC VR. Just nowhere near good enough.
anyway, regards to the headset itself. The FOV is smaller than Quest2, the quality of the displays are maybe a tiny bit better, but nothing to write home about. Velcro everywhere, so it's a pain to get it on and off.
There is a part (or parts) of the puzzle you are missing somewhere. I have built multiple VR rigs over the past 18 months using the G1 and G2 headsets with both AMD and Nvidia cards.
The G2's had USB connection issues early on, but the new G2's use a new cable and the one I built in December of last year was rock solid stable.
The Reverbs (1 and 2) work well for seated VR. Maybe yours is just deffective?
Have you tried the openvr option?
pixels per degree matters most to clarity of display, iirc the G2 is about 24, the Quest 2 is about 20, so not a world of difference no, but noticeable (to me). not knocking the Q2, for the price it has a great display, binocular overlap is fantastic, its 1 of the most easy on the eyes displays ive come across.Apparently the Pixels Per Inch of the G2 isn't really any better than the Quest 2. Biggest advantage is the uncompressed DP connection.
I've submitted a return. I'm going to leave PC VR for now until a much improved headset is released.
The main thing for me with the G2 is the small sweetspot and the awful software. No point in using all that GPU horsepower only to see a blured screen.
Didn't think much to the velcro straps either, but I could have lived with that if the quality was better.
Shame as I loved racing in VR. Typically this was really comfortable to wear and seemed to fit my face really well.
20min 45sec sums it up well
HP Reverb G2 Final Review!
So... is it a yes from me? HP Reverb G2 final review, watch on to find out!eBay G2 - https://rover.ebay.com/rover/1/710-53481-19255-0/1?mpre=https%3A%2F%2Fww...www.youtube.com
I have been debating this for sometime now....
I keep looking at that Vario but then the price makes me look away.....but it's so damn good.
Anyone using a G2 with specs?
Thanks @melmac and @andybird123
I did indeed try the face cover without the spacer. In fact, I think I tried it literally 10mins after unboxing.
It does ever so slightly increase the fov and sweetspot, but it's still far too blurry for my liking. The other issue though, is that I could then see the edges of the lenses, which gave a squared off image. I actually preferred it with the spacer.
No, don't do that. If you didn't get on with either the Quest 2 or the Reverb G2, then you really don't want the pain and hassle that comes with owning a Pimax headset. You didn't like the software side of the Reverb G2. The software side of the Pimax is even worse. If you don't like tricking with things, stay away from any Pimax headset.Hopefully something will come out over the next 12 months and I'll try again......unless in a moment of madness I give the pimax 5k OLED a go???
I'm concentrating on my triple screen rig now.
Considering it's £550, I personally think the quest2 is the allround best headset at the minute, although that has it's own set of issues.
Thing is, the G2 in the sweetspot is really good. There were other things I didn't like about it, but parcelforce are collecting it today anyway so it's definately going back.
