- 14 Aug 2018
... then the £250 12600KF would decimate the 3900X....
Not in fully multithread tasks it wouldn't - it's slower! I thought you knew your stuff!
Let me break it down as this might also be useful for the OP. The OP's stated usage case is batch exports, which will use all cores and threads so is a fully multithreaded task and will use all 24 threads of a 3900X.
In addition he is also telling us that he intends to produce video, which can depending on exactly what programs and codecs used or if doing parallel encodes/transcodes can also use all cores and threads (Handbrake iirc uses a maximum of ~16cores/threads).
In the absence of the video application used then most fully multithreaded benchmarks or applications will give a good idea of the difference between CPU's for such tasks. This is why Cinebench etc is ideal to help extrapolate that information.
I thought that you of all people would be aware of that but apparently not, though it seems like it's now more a case of trying to find fault and saving face than actually providing correct, pertinent and salient information to the OP.
