- 2 Feb 2010
- Crowmarsh
H410M-A PRO
Best Intel Socket 1200 H410 mATX PRO motherboard, turbo M.2, Intel gigabit LAN, USB 3.2 Gen 1, MSI PROwww.msi.com
When you are looking at the more budget orientated mobos you just need to be certain it has the features and connectivety you require. For example that mobo has DVI-D and HDMI video output , if you require something else it is not for you.
No point getting a super cheap board if you have to spend £50 on add on cards to give it the functionality you need. You just need a check list of requirements and find a mobo that does what you need it too.
My friend isn't a power user at all, just a general use pc will be ok. I think hdmi output will be fine for his use. I'll admit, it looks a pretty basic board.
