Nothing , still no forum <> shop linking
Relevant people have been informed, they are working on the fix / or implementing it.
If you want to order something, give sales a call and they can take your order over the phone.
Recently I've actually been undervolting and running the 6900 XT at 2300Mhz/2400Mhz and drawing 175-225W under load.![]()
I do it via undervolting but reducing the power limit is always another way to do it.Do you reduce your power limits to draw such a low wattage or does the card just only pull what it needs based on the clock speeds? With the weather warming up I'm thinking of going down this road to try and reduce the temperature in my office!
Awch! Better get 22.5.2 installed for some magic to happen!Ok after been without a GPU for almost 6 months my RMA has finally been sorted and my replacement 6900XT arrived today. It all works as it should, so far anyway!!
I had to return to Sapphire directly and they took a long, long time to get a replacement for me.
6 months, blimey!
Yeah **** that ****
Since that place is no longer active, can you share the name of it? Just curious.First thing I did
Yeah, it was a long time. One hand I am angry with Sapphire about the length of time it took, on the other hand I am just happy that they replaced the card. You see the place the card was bought closed down and Sapphire don't deal with returns, you have to go back to the place you purchased the card. Which I couldn't do. But, Sapphire stepped up and let me do the RMA through them.
So great service and crap service![]()
AMD UK Store :spicy:Since that place is no longer active, can you share the name of it? Just curious.
Wouldn't mind getting the email of an amd higher up and telling them my thoughts about their supposed store. I doubt very much it would make it through any sort of profanity filter.AMD UK Store :spicy:
Let me guess, seenutsWouldn't mind getting the email of an amd higher up and telling them my thoughts about their supposed store. I doubt very much it would make it through any sort of profanity filter.
