What DNS service do you use? (Cloudflare, Google, Open DNS etc)
10 May 2004
Sunny Stafford
This is the bit that you stick into your router settings, usually in the "WAN" or "Internet" page e.g. 1.1.1.1 and 1.0.0.1 for Cloudflare. This is off the back of the 5G Home Broadband super-thread, where I posted an issue about my router. @Firegod replied to my post saying to try inputting Cloudflare as the DNS and that did the trick for me.
I don't think I'll change because I'm happy that Cloudflare is running pretty fast for me, but just wondered what you're all using, and pros and cons :-) Public DNS is still fairly new stuff for me although I have changed DNS settings before when running Pi-Hole on a Raspberry Pi.
Cloudflare. Used to be Google in the past before Cloudflare launched theirs. Been very reliable so far, had issues with ISP ones before.
Presumably the main benefits in changing are security as 'speed' is a bit of a muchness with pre-fetching etc?
Edit: Just checked, I am using OpenDNS (222.222/220.220)
The ones that BT tell my Smart Hub 2 to use, because it works for me and I can't be bothered to replace it until FTTP arrives.
Cheers fellas. Cloudflare seems to be in the lead, but otherwise fairly evenly matched vs the other main ones.
This one looks interesting. I like the idea that you can block adult sites (as I hate porn with a passion), but still allow gambling because I do play online slots, basically the online version of fruit machines.
You might be interested in https://cleanbrowsing.org/filters/
Never even bothered with alternative dns servers before i had virgin they always just worked, virgin though every now and again half the web sites would return a error for a few hours.
They are a way for ISP or whoever to track what websites you are visiting.
