Caporegime
- 1 Dec 2010
- Welling, London
I’m looking for a hobby tool but I cannot find one anywhere.
Basically it’s like an extra pair of hands. It’s used in modelling, electronics, soldering etc.
It has a base with a column. That column has a horizontal bar across with movable crocodile clips on the ends. They can be moved to different angles. They are often found with a magnifying glass attached to the top. I’m sorry for the vague description, but its the best I can do. I’ve been looking on Google but to no avail.
would be very grateful if someone with better Google fu skills could help me out. There’s a virtual hug in it for you. TIA.
) BUT bear in mind depending on what you need holding, it's often a bad situation to have it high off the work surface. For ultimate, fine dexterity you need your wrists or forearms supported.
