Caporegime
- 7 Apr 2008
- Lorville - Hurston
So long as there is no structural damage, you will be fine.Yea the surveyor didn't even pick up on one of the windows not sealing properly because it looks like the window frame is slightly twisted/warped, and a couple of other bits.
As this is the third house we've tried to buy, shy of it falling down we won't pull out now.
I Would be perfectly fine buying a dump of a house as long as the structure is good.
I would just tear out all the interior and redo it all bit by bit but the main thing is to make sure the foundations and structures is sound. Windows, wiring, walls, floors and even the roof etc can all be done and fixed up easily.
