- 27 Dec 2005
- Bristol
So funnily enough to comply with building regs we need a first floor bedroom window to open enough for ventilation. It used to be able to be opened fully, but now it can't be due to a new soil downpipe which has been fitted for the second floor bathroom... which is why we need building regs in the first place.
It's close, like really close, but basically I've just removed the existing brackets on that portion of the wall and with the soil pipe against the wall it allows the window to open fully.
I've searched for "wall" in the building regs sections on soil pipes and can't see anything to do with a minimum or maximum gap, and the NHBC just says they should be "fixed neatly and securely to provide the correct falls". But the only 110mm soil brackets I can see for sale have a ~40mm spacer between the pipe and the wall. For example: https://www.screwfix.com/p/floplast-pipe-clips-black-110mm-5-pack/76037. These are the ones I've removed: https://www.travisperkins.co.uk/pipe-brackets/osmasoil-110mm-system-white-pipe-bracket/p/858408
If I can use a 110mm saddle bracket that'd be perfect.
Can anyone advise?
Image showing wall, pipe and top-hinged window (right) with existing brackets removed to allow for window opening:
Can anyone advise?
