Entry Level Gaming Rig
29 Jun 2016
Up Norf
Good evening,
Im looking at getting a new rig for a family friend. They play world of tanks and things around that nature.
They have a budget of around 500-£650. I have put a rig together using a 12100F i3 and an RX6600. I am wondering what other specs anybody else can come up with.
I only need system only, no peripherals needed.
Cheers
12 Apr 2020
Tempted to look at 2nd hand.. Quite a bit out there, with peopke selling bit in anticipation of new gen hardware.. Brand new 6600 card £280/£300 ish by look.. Saw pc centric do a build, he put in a 2nd hand 6700xt for £350 etc.. Check MM, you have enough posts
Caporegime
22 Nov 2005
Building a 2nd hand pc for a family friend could be a potentional nightmare at least new parts come with warranty.
why seems like PC parts fail early or just last forever.
still using a 4670k and a 980ti here daily gaming since I bought them.
2013cpu and 2015 gpu? never changed the past on my CPU either and it's still around the same temps as when it was built.
Man of Honour
23 Mar 2011
West Side
Parts fail anytine, building for somone else as long as there pre paired to take the risk buying used with no warranty then fine some great performance can be had but many a friendship been tested if things go wrong.
Man of Honour
26 May 2012
probably worth explaining the risk vs benefits of buying used and seeing if they are happy to take the risk of used components but have better performance
that way there is no comeback from them if something breaks
Man of Honour
22 Jun 2006
"What? I don't remember that conversation"
Oh, just my family? :D
Personally, I'd suggest they buy from a local PC shop. They'll likely get older and more expensive hardware, but support won't be your problem.
OP: 12100F is a good choice, particularly if you can get a cheap H610 or B660 board when the deals come up. It would be a squeeze to fit in a 6600 at that budget though:
1 X Asus Prime H610M-K D4 - Intel H610 DDR4 Micro ATX Motherboard - £82.99
1
X PowerColor Radeon RX 6600 HellHound 8GB GDDR6 PCI-Express Graphics Card - £299.99
1
X AMD RAISE THE GAME - RX 6000 Series Gaming Bundle - £0.00
1
X WD Blue SN570 500GB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS500G3B0C) - £49.99
1
X Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey - £49.99
1
X Intel Core i3-12100F 3.30GHz (Alder Lake) Socket LGA1700 Processor - Retail - £98.99
1
X Phanteks AMP 550W 80 Plus Gold Modular Power Supply - £64.99
Grand Total: £658.04 (missing case)
You could go for the 10400F, similar price and more choice of boards, e.g. MS B560-A Pro for just over £90. But, would be stuck on a dead platform.
OP
29 Jun 2016
Up Norf
Cheers for the replies guys, If it was for a direct family member I would have looked 2nd hand for sure. However as its a family member of a family member, I opted for all new. Ive gone with the below.
Gigabyte GeForce RTX 2060 D6 Rev2 6144MB GDDR6 PCI-Express Graphics Card
SKU GX-1DN-GI Write a review
Quantity : 1
£248.99
Gigabyte B560M Aorus Elite (Socket LGA 1200) Micro ATX Motherboard
SKU MB-5AC-GI Write a review
Quantity : 1
£80.00
Intel Core i3-10105F 3.70GHz (Comet Lake) Socket LGA1200 Processor - Retail
SKU CP-69G-IN Write a review
Quantity : 1
£80.00
Kolink Modular Power 500W 80 Plus Bronze Modular Power Supply
SKU CA-04H-KK Write a review
Quantity : 1
£35.00
SKU MY-0AK-TG Write a review
Quantity : 1
£50.00
TeamGroup 512GB Vulcan G SSD 2.5 SATA 6Gbps 3D NAND Solid State Drive
TeamGroup 512GB Vulcan G SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
SKU HD-00H-TG Write a review
Quantity : 1
£47.00
TP-Link 300Mbps Wireless N PCI-E Adapter
SKU NW-054-TP Write a review
Quantity : 1
£14.99
Kolink Inspire Series K11 ARGB Midi Tower Gaming Case - Black Window
SKU CA-06B-KK Write a review
Quantity : 1
£39.95
Subtotal
Delivery (Free Shipping)
£0.00
incl. 20 % VAT
£99.31
GRAND TOTAL£595.88
18 Oct 2002
Sheffield
Are there any other HDD's you will be adding to the machine that you already have? Even if its rotating ferrous.
You can't inflict a 500mb size sole hard drive onto someone. You just can't do that.
But I can't see anywhere you can squeeze to fit in the extra £33 and stay under £600.
There is a b grade 1tb m.2 @ £70 :
And a B grade LGA1200 mobo including wifi @£70 which would save £25. [you would need to have a spare sata cable in case the mobo comes with nothing. The potential lack of io back plate is the usual biggest risk on these b grades]
OP
29 Jun 2016
Up Norf
Yes this was one issue, i do have a Samsung 860 SSD which ill pop in as well, its only 256gb. Ill explain it may need more storage sooner rather than later.
29 Sep 2010
You can buy a h610 motherboard and a 12100f for £141 right now....have you placed the order?
Swap the sata ssd for an nvme. £48 for a 500gb sata ssd is terrible value, 1TB go on offer all the time for about £60 for a much superior MX500.
Would have definitely spent the extra on a better psu too, for not much more you could have had a far superior/more reliable psu.
4 Oct 2019
Belfast
18 Oct 2002
Sheffield
@Defy Belief
There might be a value in buying everything from one place when building for a friend. If you end up in an RMA situation it lessens the likely hood of blame vs other components and rejected RMA. It also gives you a potential option of telling the user to call OCUK themselves rather than onus on friend to take responsibility for all things diagnostic.
29 Sep 2010
@Defy Belief
If it were a pre-built machine, i'd agree with you, but its not.
Which to be honest, the OP may as well do if warranty is a concern, 11400f/3060 builds for £650 all the time etc, leaving them with a better cpu and gpu too. That entire build posted above is below average for the money paid.
10100F with a b560 board for £160 is absolutely terrible value for money, its 2 years old. Same as £250 for a 2060, old hat tech.
OP
29 Jun 2016
Up Norf
To be honest after I posted the original question, they told me they wanted it below £600 and had to include a WiFi option. I could have saved some money getting parts from different places but I plan to build it, hand over the invoices and hope to never see it again. As far as I'm concerned, I couldnt get a pre-built similar spec PC for anywhere near the price.
