- 2 Feb 2010
- Crowmarsh
Good point, will give it a go.Try your fingers to see if there's an issue.
I have a Ryzen 3900X setup, will have a check this evening for you.Does anyone have a Ryzen 3000/5000 system to test with? I think I worked out why my P6 Pro doesn't always go to file transfer mode when connecting via USB, tapping the option it tries for a bit then flips back to charging mode, takes a few goes for it to actually go into file transfer mode. Yet testing it on an Intel system it changes over straight away without issue. Haven't had this issue with my previous phones but I'm curious if that's to do with the USB chip used in the P6 not liking AMD's USB controller.
Any good sim free deals?
Even if it’s refurbished got a relative looking for a Pixel 6
Not sim free but with a good sim deal
This any use to you. Pixel 6 £499 sim free.Any good sim free deals?
NoDoes face unlock exist yet for this phone?
Rumors it may get added on the pro.Does face unlock exist yet for this phone?
Yeah the rumors are months old at this point. Guess they've given up and maybe a pixel 7 feature...Rumors it may get added on the pro.
Probably the most likely scenario.Yeah the rumors are months old at this point. Guess they've given up and maybe a pixel 7 feature...
I tested this out just now. I'm seeing the same issue. Will try with different cable / usb port later.Does anyone have a Ryzen 3000/5000 system to test with? I think I worked out why my P6 Pro doesn't always go to file transfer mode when connecting via USB, tapping the option it tries for a bit then flips back to charging mode, takes a few goes for it to actually go into file transfer mode. Yet testing it on an Intel system it changes over straight away without issue. Haven't had this issue with my previous phones but I'm curious if that's to do with the USB chip used in the P6 not liking AMD's USB controller.
Had some new ugreen cables arrive the other day and just tested with those, they work completely fine straight away. My Anker, Aukey and OP cables have the issue though.Does it on my i5 4th gen desktop. Using a better cable fixes it for me.
Maybe some people just don't have very pronounced finger prints.
