Running older game in windows 11 ?
19 Feb 2007
Northampton
Trying to get The Chronicles of Riddick:Assault on Dark Athena to run on Windows 11 but each time I go to launch it, It gives me the following error -
Tried all the usual stuff, Windows fully updated, 6950XT driver fully updated, Run in compatibility mode etc etc.... but nothing works, Also tried running on my flatmates rig which has a 3090 to see if it was an AMD specific bug, Same error, Anyone got any ideas ?
Some games check for the amount of vram and other graphics requirements like DX which are needed to run. you may have more vram that the software can see/count or only be checking for DX 9 or lower whereas you have a higher DX version that may not be recognised. There may be some .ini file in the game that could be edited to recognise larger vram sizes.
I had a good dig around and found a config file in in the user/appdata/local folder and sure enough the VRAM was set to some zany number, Set it to my cards max and away it goes :)
Have a look in the game's folder in Steam - steam apps - common - game name. See if there is a configuration application that lets you set up your graphics settings?
Not in the game directory but found it in the hidden appdata/local folder :)
Nice one, glad you're all up and running.
It's a PITA when games you enjoy suddenly stop working for some unknown reason.
