- 21 Oct 2011
- ST4
SainsburysWhere from? Not spotted those before.
£2.60/litre is high - but just shows how nuts Lucky Saint is.Sainsburys
They do another one now too, same size bottle and Session Ale, actually really very good for what it is: https://www.sainsburys.co.uk/gol-ui/product/low-alcohol-drinks/session-ale-05-500mlSainsburys
gruntinggrowler.com
On my blade machine Heineken 0 is £10 cheaper than normal Heineken. £22.99 vs £32.99 8l kegs.Proof pls
(as I spend a fortune on it)
I could never understand the point of alcohol free lager.
Maybe things have improved since then but I still would not try it myself.
I don't like the taste of lager, I only liked the effects of the alcohol, it was an ends to a means. Now I have not drunk in over 20 years and I have no plans to start again.I'm teetotal and don't want to limit myself to fruit juice, soft drinks and water so alcohol free lager does the job very nicely for me. We've also got quite a few alcohol free spirits. As with the lager, some are better than others.
And yes, they've definitely improved. Can't say I understand why you'd refuse to try them though, worst case is you try one, don't like it and don't have another.
Game changer - I always wanted one of those but didn't want to further encourage drinking. The fact they do 0% is great news. Will have to start researching them!On my blade machine Heineken 0 is £10 cheaper than normal Heineken. £22.99 vs £32.99 8l kegs.
Am I reading this right - they are like 500 quid?I don't use it everyday, sometimes I have wine instead.
You can afford it.Am I reading this right - they are like 500 quid?
Lots of them don't taste like lager, because they're not trying to. Plenty of pale ales, IPAs, APAs, sours, stouts etc.I don't like the taste of lager, I only liked the effects of the alcohol, it was an ends to a means. Now I have not drunk in over 20 years and I have no plans to start again.
The good days are coming to an end - mortgage paperwork came through last week; exchanging/completing soon enough and they I will be properly brasic.You can afford it.
This isn't a great review:
Beer Blade machine, dispenser, draught, home bar, beer on tap | eBay
This works fine, was being used until recently in a bar using 0.0% beer. Theres a free keg of 0.0% heineken with it. If you dont know how these work, they chill your 8 litre blade keg down over a 16 to 24 hour period in the machine, and dispense cold crisp beers.www.ebay.co.uk
He is flogging it because it isn't great for 0%?
He doesn't I'm just suspicious of someone flogging my only use case.Where does he say its isnt great?
I actually can't believe these are 500 quid. @200sols what's the game? Are they worth that much $$? I'd also hate for it to go wrong after a year or 2...or 5 at that cost.
Edit: Yeah can't get the maths to work on that £2.45/litre versus a low of £1.67/litre - £1.92/litre for the cans.
aren't there some reasonable squashes now ? - keep meaning to explore that marketI'm teetotal and don't want to limit myself to fruit juice, soft drinks and water so alcohol free lager does the job very nicely for me
