I've set up my old PC in the kitchen for media streaming but because the tower is kind of hidden away behind the table it's a bit annoying having to stretch over to turn it on. I've tried to get wake on keyboard to work but it's not having it.
Things I have tried:
One other thing I've noticed which is odd is that the keyboard doesn't work straight away in Windows, i.e. it takes a couple of settings before I can press a key to access logon screen. It's like it's waiting to be initialised or something. However, it works fine in the BIOS without any 'warmup' time.
This is really annoying because I literally had the opposite problem on my desktop PC a couple of years ago, whereby accidentally pressing a key would make the PC power up!
Motherboard is GIGABYTE GA-Z77-D3H Intel Z77
- Gone through BIOS to make sure wake on keyboard is enabled and any other relevant setting, make sure all USB support is there etc
- Set all keyboard devices and USB hubs power management to allow this device to wake the computer and (where possible) unticked allow the computer to turn off this device to save power
- In windows power plan, disabled USB select suspend
