OcUK Staff
- 1 Apr 2014
- OcUK HQ
The Lian Li Lancool III provides amazing options for creating your next gaming PC. This case has great out-of-the-box cooling, including a front mesh panel that offers exceptional airflow in parts thanks to four pre-installed 140mm fans. The Lancool III can additionally accommodate up to three 360mm radiators, six additional fans, and multiple pump mounting positions. This case is ideal for high-end builds. With a large internal capacity, you’ll have plenty of options for components from E-ATX motherboards, and GPUs up to 420mm long, as well as multiple storage drives. Furthermore, with the extensive cable management options, your PC build will look clean and tidy.
Lian Li Lancool III Full Tower PC Case - White @ £159.95 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-full-tower-pc-case-white-ca-7ax-ll.html
Full Tower Case, Supports E-ATX Motherboards, Front Mesh Panel with 51% porosity, Supports 3 x 360mm radiators, Excellent Cable Management, 4 x 140mm Fans Pre-Installed
Only £159.95 inc VAT.
ORDER NOW
Lian Li Lancool III Full Tower PC Case - Black @ £149.99 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-full-tower-pc-case-black-ca-7aw-ll.html
Only £149.99 inc VAT.
ORDER NOW
Lian Li Lancool III RGB Full Tower PC Case - White @ £169.99 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-rgb-full-tower-pc-case-white-ca-7az-ll.html
Full Tower Case, Supports E-ATX Motherboards, Front Mesh Panel with 51% porosity, Supports 3 x 360mm radiators, Excellent Cable Management, 3 x 140mm RGB + 1 x PWM Fans Pre-Installed
Only £169.99 inc VAT.
ORDER NOW
Lian Li Lancool III RGB Full Tower PC Case - Black @ £159.95 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-rgb-full-tower-pc-case-black-ca-7ay-ll.html
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
