**LIAN LI LANCOOL III AVAILABLE FOR PRE-ORDER NOW**
OcUK Staff
1 Apr 2014
OcUK HQ
The Lian Li Lancool III provides amazing options for creating your next gaming PC. This case has great out-of-the-box cooling, including a front mesh panel that offers exceptional airflow in parts thanks to four pre-installed 140mm fans. The Lancool III can additionally accommodate up to three 360mm radiators, six additional fans, and multiple pump mounting positions. This case is ideal for high-end builds. With a large internal capacity, you’ll have plenty of options for components from E-ATX motherboards, and GPUs up to 420mm long, as well as multiple storage drives. Furthermore, with the extensive cable management options, your PC build will look clean and tidy.
Lian Li Lancool III Full Tower PC Case - White @ £159.95 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-full-tower-pc-case-white-ca-7ax-ll.html
Full Tower Case, Supports E-ATX Motherboards, Front Mesh Panel with 51% porosity, Supports 3 x 360mm radiators, Excellent Cable Management, 4 x 140mm Fans Pre-Installed
Only £159.95 inc VAT.
ORDER NOW
Lian Li Lancool III Full Tower PC Case - Black @ £149.99 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-full-tower-pc-case-black-ca-7aw-ll.html
Only £149.99 inc VAT.
ORDER NOW
Lian Li Lancool III RGB Full Tower PC Case - White @ £169.99 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-rgb-full-tower-pc-case-white-ca-7az-ll.html
Full Tower Case, Supports E-ATX Motherboards, Front Mesh Panel with 51% porosity, Supports 3 x 360mm radiators, Excellent Cable Management, 3 x 140mm RGB + 1 x PWM Fans Pre-Installed
Only £169.99 inc VAT.
ORDER NOW
Lian Li Lancool III RGB Full Tower PC Case - Black @ £159.95 inc VAT https://www.overclockers.co.uk/lian-li-lancool-iii-rgb-full-tower-pc-case-black-ca-7ay-ll.html
ORDER NOW
13 Mar 2007
South Yorkshire
Really like this case after seeing some videos on YouTube, shame that they didn't launch the RGB version with the new infinity mirror fans and controller, or atleast offer a bundle deal up for both items.
26 Mar 2007
Nottinghamshire
Just seen the review of these on Gamers Nexus and have decided that this will be replacing my Corsair 275R if timelines or delivery are soon.
Would just like an eta...in weeks is fine...
24 Jul 2022
Manchester
why does the black mon RGB say "pre order" same as the otheres yet come back with
"Product CA-7AW-LL is not available at the moment."
If you try adding to the basket whereas the rest don't ?
