Ooooh sorry, long overdue actually catching up here! Not much to report here apart from a general lack of quality regular riding. Power numbers are
pretty good still and I'm
quite consistent even without the regular riding, just life getting in the way!
Did a club social 2 weekends ago and went up Gospel pass. Legs felt good and mostly riding high tempo for the climb off the front with a few other hitters. Knowing it's brutal at the top, was good to cross that one off as I'd not been up that side for a couple of years. This weekend they're talking of going down to Chepstow and back up through Gloucestershire & Herefordshire villages for a 100 miler. I've not done one for several years, so I'm really up for it and want to do it - knowing I'll not really struggle legs and fitness wise... But time in the saddle I may - especially as having '2 meal stops' has been mentioned - making me think it'll be an 8 hour slow as hell ride and not a 6 hour like I've done before!
Earlier this month had a few 'undercarriage' issues. Thought it was after my 2 weeks (20 days) off riding for my holiday as seemed to coincide when I rode a little more. Eventually narrowed it down to the chamois creme I have been using since the winter. So '
Chamois Buttr Eurostyle' and hot weather seems to cause some minor irritation for me, almost like a shave rash sore and itchy. As soon as I stopped using the creme a couple of days it was resolved. Switched back to an old pot of my previous favourite (Assos) and it's continued solved so have
ordered some more (although it's a different tub, I hope it's not different stuff!). Will use up the Buttr in the colder weather!
My original TICKR was replaced start of this year with the Gen 2 (Black) one. I've had several issues with it, but not enough to raise a support ticket. It's burned through a couple of batteries, I've had a couple of really high readings with it, also some really low ones. I think it's the strap, I've switched it over to the 'amazon' strap I ran with my original the last couple of years and it seems to have settled down. It's either the strap connections/poppers - solved by using a strap which doesn't undo at the poppers, or it's sweat ingress that was also draining the batteries, which is partly better as this strap has material behind the unit, so it gets less movement and amounts of sweat around it's battery cover. Just enough issues for me to say I don't 100% trust it, but also reliable enough that I've not done anything about it...
My original Gen 1 I purchased on 18/10/2014 so it was just over 7 years old. Was probably 6.5 years old before it saw a few issues, generally it not 'waking up' and I changed the strap over. That did solve it for a time, but that seemed to come back and it got progressively worse. In the end I was taking the battery out when not in use, then putting it back in, which wore the plastic door out. But when it was on it was still working perfectly.
Would buy the Gen 1 again if I could!
I think you can use zwift to calibrate without using the wahoo app. I think I used the app once and never again.
This. I'm the same, even with having mostly all Wahoo kit now I don't really use their apps. Only regular one I use is when my ELEMNT hasn't uploaded and then trigger it within there. I've done a couple of spindowns with my KICKR20 but really unnecessary - it self calibrates. Did them when new and a couple of weeks in then have not bothered since. It's reliable and 'just works' - like most Wahoo devices.
If you look at a head unit and see the numbers with some big digits then you end up telling yourself you can only do X for Y length of time. Just get stuck glued onto a wheel and dig deep and you may see a PR.
It's that it though - why riders riding on 'feel' rather than power end up going so well sometimes. Think in the TDF that Stefan Bissegger was mentioned sometimes rides without power - which is pretty insane for a young TT'er in the current generation. Fairly sure I'd heard it from some of the older ones like Alex Dowsett learning how to pace without power and just by feel when doing domestique duties and such.
Super Sticky Kush is the bar tape of choice for 3x World Champion Peter Sagan. Fusing performance and style, Supacaz delivers the only bar tape worth dr...
www.specialized.com
I like supacaz having taped quite a few of them, lizard skin DSP comes in thicker versions if you want it a bit softer.
I don't mind thinner tape so Supacaz suits me, I also like the fade style on the drops.
I put the real thick Lizard Skins DSP on my turbo bike with some gel under it, it's very sold and strong feeling. It has made the alloy bars almost sweatproof - which was one of my aims! Expensive stuff though and not sure I'd like the feel when out on the roads. Nor the look. Have nearly always used 'standard' type cork tape on mine. Doesn't wear that badly really considering the abuse it gets. I've always wanted to try some supercaz but always been put off by 'sticky' tapes when I've felt them - just paranoia about them getting dusty and looking dirty the whole time...
