brand new HUE Outdoor PIRs for £20 each over the weekend,
Where did you buy from? Assuming they're the ZigBee ones? I've been keeping an eye out, but at £45ea they're a bit pricey.
Voice control via echosInnr are good quality though not necessarily cheap.
How do you have everything hooked up? As that will obviously influence what button you can buy
Thanks.Yes, easiest way is to create a scene in the hue App and then trigger this through the Google Home app.
Would highly, highly recommend home assistant if you want real control!
Just create a group hue "Living Room" and that will do it. At least it does for Alexa. Turning them on/off will simply turn them on to the last manual setting (colour/brightness) again.Hoping for some advice.
I've recently bought some white ambiance filament bulbs for my flat, I originally bought the standard white bulbs but they were a bit warm for me so will be on the MM soon.
I have sent the bulbs up in the Hue app and have now linked them to Google Home. What I want to know is can I set the bulbs to default to a brightness and colour when I just say 'Living Room lights on'?
In the hue app you can set this but it doesn't work when I do it through google.
I'm sure plenty of you have Hue of various types so some help would be appreciated! My Googling hasn't helped much unfortunately...
Thanks in advance![]()
Got these today fresh from Aliexpress, not sold in the UK for some reason. Got a couple for now to try but first impressions are pretty good so far.
Forgot to add, added a couple of automations yesterday, using the sun azimuth angle to make a binary sensor to whether the sun is shining in the front or back of the house, and closes the relevent blinds in that bedroom if the outside temperature is more than 24c, then opens them back up when the sun has moved around or set.
You want ZigBeeJust smart bulb in my bedroom.
I was going to expand until what I discovered.
I assumed the bulb would be wifi network only, it was advertised as a wifi bulb. But the only thing wifi about it is it uses that connection type to connect to the internet, I couldnt control it until I had setup an account on some china based server. It can only be controlled via the app if online on the internet. As its done via a server, it also phones home a lot when idle. I didnt bother to setup the echo device I purchased.
I looked into proper wifi only or bluetooth bulbs and seems they much more expensive.
Analog switch in the sense that the Hue lights in my lounge and living room are controlled in an absolutely traditional way thanks to these switches. Any individual walking into the house would instantly understand to turn the lights on/off they would just press the switch/rotor in. And to dim/brighten then simply rotate left/right. ie: They work just like conventional dimmer switches, albeit they even light up when in use etcAnalog switch in what sense? Physical action or mechanism stays in place? Surely lots of the Hue switches have physical buttons.
