Got a DNO\G98\G99 question though, I have received a G98 letter from my DNO via my installer confirming installation of the system, but it is a 5.0KW Growatt solar inverter, 5.4KW of Panels, a 3.0KW Givenergy battery inverter and an 8.2KWh battery, so things I've read suggest it should require G99. Wondering if maybe the Growatt has an export limit to avoid needing G99 or something? Anyone more knowledgeable about this know why I may only have a G98?
Your installer clearly only applied for a G98, and will as you say export limit your setup. Either they or there is an administrative error somewhere between your installer and the DNO.
