There may not be many options left, but I'll say what I've tried.
As I'm very sensitive to noise, i overclock my GPU (MSI Radeon RX 6500 XT MECH 2X 4GB to be at the same rpm from warm to close to maximum operating temperature, but always make sure that it still remains at suitable temperatures when it is working hard. This does mean that even in basic games it is loud, but i can learn to filter it out. However, I keep having to change the RPM myself as it keeps making strange idling noises and it just doesn't stay the same. It seems to be related to the temperature of the card as to weather it makes this sound at say 48% or much higher. It only seems to consistently stop if i fix the rpm at 60% or higher or under 35%. But the software doesn't let me go under 30%. The AMD software is bad anyway as it doesn't remember your custom profiles if you set more than one. I used to game on Linux and moved to Windows as I thought it would be much better in terms of graphics overclocking programs but it seems worse from my experience.
To allow me to run my GPU speed as low as possible, I've added a 140mm case fan at the top and 120mm fan at the rear and due the the cases design, the GPU is at the bottom, right above the air intake.
At this stage, if the card won't make a consistent noise, I want to try and get it to run at a lower RPM while keeping it at a safe temperature. So I want to work out what sort of modifications I could do to my case. Is there any water cooling methods that can be done? Such as a radiator over the air.
This is my PC case. There will be a decent amount of room under the GPU, especially if i move the SSDs elsewhere. Just need to work out if any cooling solution to reduce the GPU fan speed will be possible.
drive.google.com
