Behave it's similar to a 1060, 1650 or even a 980.The 6500XT can't even run some modern games above single digit fps at 1080p it's really that bad of a card
Its far from similar, those gpus are all running 40-60fps whereas the 6500XT is single digits so clearly there are issues. whats the point in buying a card which only works properly in half your games.Behave it's similar to a 1060, 1650 or even a 980.
Target market isn't modern games at maximum details, it's gamers playing Fortnite and the like
The 6500XT can't even run some modern games above single digit fps at 1080p it's really that bad of a card, the 3050 is overpriced and all but as a GPU atleast it's a technically competent card and will run modern games at 1080p.
Wake me up when HUB learn to use the FSR button! Seems that HUB likes to forget that AMD designed the 6500xt to use FSR,Its far from similar, those gpus are all running 40-60fps whereas the 6500XT is single digits so clearly there are issues. whats the point in buying a card which only works properly in half your games.
Back from the dead!
Yes, we have an 8GB 6500XT now!
Wake me up when HUB learn to use the FSR button! Seems that HUB likes to forget that AMD designed the 6500xt to use FSR,(Not to forget RSR,![]()
Introducing Radeon Super Resolution and FidelityFX Super Resolution 2.0
AMD Radeon™ Super Resolution (RSR) is our new in-driver spatial upscaling solution powered by AMD FidelityFX™ Super Resolution (FSR) 1.0. It allows users to ...youtu.be
He didn't full comply,I told Steve to stop using FSR and DLSS in his benchmarks, we want to see native results
The Nvidia 4070 got some benchmarks with DLSS (that is such a big selling point for the 4070) but the poor AMD 6500xt wasn't allowed to use FSR!
Back from the dead!
But running a card at 4k dlss perf (1080p) to make a card look good is ok? Thats the rtx4090 in cp2077 with uber rtSure as long as RT is also turned on as its only done then. Or like with Callisto protocol when FSR is on by default.
Running the card at 1080p FSR (720p) to try and make a card look good is absurd. It wouldn't even look good as all the other cards also running at 720p will jump up significantly.
That makes it into the overall card comparisons? No it doesn't.
The only place that is shown is for RT only comparisons. 1080p is also significantly better than 720p. But sure, to appease you can ask them to throw the 6500 XT into the mix.
Using FSR/DLSS at 1080p without even RT, is ridiculous. Also wouldn't even help the 6500 XT move up the ordering.
Thanks for not actually understanding my reply. Using any upscaling isnt a`valid` comparison.
Nvidia/AMD produce a range of products, at different price points, with difference performance targets. If people don't think that the 6500xt has enough performance then AMD and Nvidia will gladly sell them a more expensive card with a higher profit per card. For some people the 6500xt enables them to play the games that they want to play at max settings with good frame rates for under £150, eg Elder Scrolls Online, so why pay more?Sure as long as RT is also turned on as its only done then. Or like with Callisto protocol when FSR is on by default.
