I'm using a decent pass through crimper as well. I've changed all connectors that go into the switch so everything is working as it should now. I moving to a patch panel later in the year which'll completely get rid of this issue
I have a Gen1 cloudkey which has been extremely slow recently as well as going offline.
Today I thought I'd do a hard reset to see if it would fix things.
Downloaded the recent back of all settings
Reset the cloudkey
Tried to restore the backup I had but I'm getting "The backup file you are trying to load is from a newer version of the UniFi Controller and cannot be used with this controller."
I've logged in via SSH and updated to the latest cloudkey firmware but still getting the same error
Does anyone know the link to the controller firmware? ... I forgot to check which version but it maybe the latest release.
Nope. There is no ‘radio’ reason to do that. It’s only held on the mount by a clip and one small screw so natural vertical mounting with the weight holding it down on the mount is probably best. I usually put a clear tie-wrap around the AP and whatever I’m tying it to as well as the mount isn’t the strongest given the weight it’s holding in place.I’m mounting my Flex HD soon, it’s going to be high up, near to the roof of the n a standard two story house. I’ve read some people saying in this sort of situation it’s better to mount it upside down. Any truth in this?
From the description I thought that was what they had done?You could set it up from scratch, update to the latest version through the GUI and then restore the backup.
That was my plan mate but wouldn't allow me to setup the cloudkey from scratch.You could set it up from scratch, update to the latest version through the GUI and then restore the backup.
Looking at replacing FlexHD and U6 Lite with one mounted in the loft, got a 4 bed detached house.
Correct.I'm assuming that on the Dream Machine console I just remove my BT login and sign in using my EE credentials and it'll be a trouble free process?
