I have several 10mm bolts that are both rusted and a bit rounded I need to remove.
I was wondering if these extractors would do the job the smallest extractor being 10mm. I'm not sure if a 10mm extractor would be any good on a 10mm slightly rounded bolt?
www.toolstation.com
Minotaur Bolt Grip Nut Remover Set 5 Piece | Toolstation
Easily remove stubborn or broken fasteners with this Minotaur bolt extractor set. With a choice of five sizes from 10-16mm, use it to remove broken studs, pipes, set screws and grease fittings – the kit is comfortably equipped to take on a larger range of bolts in engines, furnaces and...
Pain in the ass getting 16 year old suspension arm bolts out!
