I've noticed that the gear ratios on the ZF8 speed in my M240i are a bit weird. The difference in engine speeds between all changes seem pretty similar, apart from the 3-4 change which is much shorter. You can see it in this video:
(skip to 1:25)
From the video:
1-2 Shift: Drops ~1500rpm
2-3 Shift: Drops ~1500rpm
3-4 Shift: Drops ~1000rpm
4-5 Shift: Drops ~1500rpm
5-6 Shift: Drops ~1500rpm
Not sure about 6-7 and 7-8 as you can hit the limiter in 6th, but I notice the same thing even at much lower RPMs the difference is still very noticeable.
Do we know why 4th(?) gear is shorter than all the others? My brain can't work out if it's 3rd or 4th that's the shorter gear.
From the video:
