Then why hasn't it been done?What a load of tosh, with a bit of engineering you could design robots to refill an entire Costco in minutes and not spill a single item.
I'm interested in seeing a system which can fill a Costco in minutes. Do you have a link?Cost
Expensive updates
Expensive repairs
And it has been done, but mostly in area's where money is no object and willy waving is more important.
Like I said, it'd take a bit of engineering. We've already got robots that can fulfill orders in seconds, robots that can manage entire shipyards, robots that can clean almost anything, it's really not that much of a stretch to imagine that they can be built to stock supermarkets.I'm interested in seeing a system which can fill a Costco in minutes. Do you have a link?
It hasn't been done then.Yes I see.
Give me 38 years and I will provide one.
It's an interesting system but it's not going to fill a Costco in minutes. I was after @aVdub backing up his claim, which it seems he can't do.It's not exactly what you're after I know but Ocado already have a warehouse filled with robots packing 2 million items of online food orders per day, so the tech is there in some respects -
Maybe robots could be built to stock supermarkets, the issue is your claim "with a bit of engineering you could design robots to refill an entire Costco in minutes and not spill a single item".Like I said, it'd take a bit of engineering. We've already got robots that can fulfill orders in seconds, robots that can manage entire shipyards, robots that can clean almost anything, it's really not that much of a stretch to imagine that they can be built to stock supermarkets.
Back in about... 2001-ish, I did the central and underfloor heating in a 400m long building in Holland. In fact, I was working for Schermer at the time and this is their page about it. Even back then they had automated forklifts which could fetch anything in the warehouse and load it in a truck. They could handle pallets of eggs without breaking a single unit. This was 21 years ago. Since then the tech has come a long, long way. It's not that much of a stretch to imagine that a whole shop could be restocked in minutes.
This gimmicky "look at my wavey arm" is nothing more than a toy, put some real industrial tech and research behind the theory and this is very much possible.
That said, much of the packaging would likely need to be designed around it.
And yes, these machines could fill an entire supermarket in minutes. You'd be amazed what modern robotics can do.
Three robot forklifts moving pallets a short distance from truck to warehouse floor. 54 pallets in 43 minutes, 49 seconds. 2½ minutes for one robot to move one pallet. A Costco stocks around 4,000 items on pallets and they're in much more challenging positions.
I'm not convinced because you're not being very convincing. There's only so fast you can move a pallet from truck to a precise position in the store. Have a got at explaining how you'd eliminate the challenges and streamline the workflows.I'm not really sure what you're expecting, I clearly said that these robots could be engineered, which they absolutely 100% could - that doesn't mean that they exist. Even in that vid you linked above there are massive gaps in the process, they use people with clipboards for example whereas QR or barcodes could eliminate those people entirely. These are of course challenges that would need to be engineered out, they're not ready-made solutions. That's what engineering is, eliminating challenges and streamlining workflows using technology.
If you're still not convinced that an entire shop could be engineered to restock in minutes then I'm not really sure what else to tell you.
From what I can see, I think your getting too hung up on the time frame diddums stated, which to be fair is quite a low estimate.I'm not convinced because you're not being very convincing. There's only so fast you can move a pallet from truck to a precise position in the store. Have a got at explaining how you'd eliminate the challenges and streamline the workflows.
I'm only getting "hung up" on the claim that was made.From what I can see, I think your getting too hung up on the time frame diddums stated, which to be fair is quite a low estimate.
Regarding having shops stocked by robots, its not just the equipment but the shops themselves (floor plan and the way space is used) would need a redesign to work with a robotic work force. You would need to segregate customers from the robots on H&S grounds. Goods are delivered to shops throughout the day so what ever robotic solution is choosen would need to be capable of stocking the shelves at anytime of the day and not just when the shop is closed. As has been mentioned how goods are packaged would need to change, but you would need a universal solution. You can't have custom packaging. to work with the different solutions that Tesco, Sainsburys, Asda, Morrisons etc.. comes up with.
I'm sure if you had a viable idea you'd have aleady patented it yourselfI mean, I could literally describe something that would achieve this but I'm not sure it's worth it, you're not looking for sneaky patents are you?![]()
YupFrom what I can see, I think your getting too hung up on the time frame diddums stated, which to be fair is quite a low estimate.
Regarding having shops stocked by robots, its not just the equipment but the shops themselves (floor plan and the way space is used) would need a redesign to work with a robotic work force. You would need to segregate customers from the robots on H&S grounds. Goods are delivered to shops throughout the day so what ever robotic solution is choosen would need to be capable of stocking the shelves at anytime of the day and not just when the shop is closed. As has been mentioned how goods are packaged would need to change, but you would need a universal solution. You can't have custom packaging, to work with the different solutions that Tesco, Sainsburys, Asda, Morrisons etc.. comes up with.
Feminists are already trying to get them banned in the US, decades before we even have the technology. Because they're afraid of being replacedRobot sex slaves will bring about the end of natural human reproduction.
