Upgrade advice
10 Feb 2014
Hi folks
Looking to upgrade and have chosen the following:
  • AMD Ryzen 9 5950X AM4 Processor
  • MSI MAG B550 TOMAHAWK MAX WIFI ATX Motherboard
  • Corsair Vengeance RGB Pro SL 32GB (4x8GB) 3200MHZ DDR4 RAM
  • Thermaltake Toughpower PF1 1050W ARGB Full Modular Power Supply
  • Be Quiet! Dark Rock 4 CPU Air Tower Cooler
Can anyone see any issues with this setup i.e. ram clearance with the CPU fan / Adequate cooling etc.... I also have 2 existing SATA HDD drives and a SATA 512GB SSD so need to ensure the PSU will cope
Thanks in advance
Can you not wait 2 weeks for AM5 to be released ? It may not be great but it is good to have options.
Your PSU is overkill for your needs but you do not mention a gpu, that cpu does not have an IGPu so what you have listed is not a working PC.
A very good point, I was going to wait for AM5 in the event that AM4 might reduce in price, but I've heard that may not happen. Also, are there sufficient AM5 boards around?
My GPU is a Radeon RX590 GDDR5 8GB
Thanks for the quick response
There are price cuts already, but OCUK don't seem to have applied them yet, rumours are that they'll drop even further (£200 for 5800X, £300 for 5900X, £400 for 5950X), but we haven't seen those kind of discounts in the UK, just selected stores in the US and other places, I think.
If I recall correctly, when Zen+ got a price cut (before Zen 2 released) it lasted a month or two and once the stock was cleared they didn't go back to that level, but the market is pretty competitive now, PC shipments are down and the shelves are stuffed.
Thanks Tetras, my thinking was if any chip shortage may affect any discounts but based on yours and Haz's advice I might wait it out 2 weeks and see what happens.
I was looking at a high wattage CPU as wasn't sure if my current 750w was any good. It's currently powering an AMD FX-6300 on an MSI 97A-G46 but USB devices keep dropping out and I've had to under volt my GPU due to non-heat related freezes. Could be the motherboard but I'm no expert at all
A 5950x uses approx 240w when it is fully loaded, a 750w psu will be fine for that cpu with most gpus. RX 590 is 225w part according to Anandtech so you should have plenty of room with the 750wpsu. Of course that is assuming everything is working correctly and the gpu is getting on a bit so could be tempermental.
If you were thinking of changing the PSU then I am not sure your chosen one is an ATX 3.0 spec. In general Thermaltake make excellent psus but if I was buying now I would be looking for the new spec with the new cards in mind. Of course you would then need to make sure it had the connectors you need for the old Polaris card but nothing is ever easy is it.
Thanks Haz - agreed, enough to make your head spin. Might push the boat out and see about a new GPU but just means laying more cheddar cheese!
There have been some excellent deals on gpus over the past month or so but prices are variable. New gen of gpus in the next 6 months so it is kind of a perfect storm for upgrading. Not sure if you just game or have a workload in mind but there is real choice and competition at the moment , that is not always the case. The competition helps keep the prices down but it needs more thought to choose the correct card.
If your gpu is still doing what you need it to do then there is no harm in waiting. With Ethereium changing its rules there are going to be 100s of thousands of gpus hitting the second hand market. I am not sure we have ever seen a situation like this and I am clueless to what it will do to resale values and the second hand market. You may be able to pick up a 3080 for a steal in 6 months time but we will have to wait and see.
Main use is gaming and 3D modelling / Rendering. I might look at upgrading post AM5 except the gpu for now, then maybe look at the latter next year.
Can you recommend a suitable PSU if I did go for the specs at the start of this thread?
shelves are stuffed
I see a lot of CPUs sold out (e.g. here at OCUK you have to preorder the 5600 or 5600x); do you think there is the kind of overstock that might lead to good discounts (especially with the very strong dollar right now)?
/edit:- no you don't! But it's also not exactly discounted.
OCUK seem to have run down their AM4 stock (motherboard availability, for example), at least that's my impression of what they're doing, but other retailers don't seem to have any stock issues. If there are huge discounts on offer (like with Zen+ prior to Zen 2), then I don't think the weak pound will matter.
I'd argue a lot of companies have probably been running stock down or just keep smaller amounts of stock in the first place...
As to discounts, I bought my 5950x a few months back when the prices dropped, it's gone up due to the pound etc in most places so I wouldn't be holding my breath for any major discounts personally.
I think this may be an AMD thing; they have been working on keeping their average selling price high - and I guess they can use the wafer allocation for things like AM5 chipsets. I think this cements my decision to target Black Friday as the buying point.
Thank you both!
Hi folks
Thanks in advance
So I'm actually going to go with the rest of the group and suggest that you wait for AM5 or 13th Gen Intel.
Here's Buildzoid speculating about AM5 which he cites as situational. I think you have that situation.
Do you use any 3D modelling that can make use of CUDA cores? I know that using CPU for 3D rendering has it's own benefits, I'd just ask because if you didn't know, 3D rendering using a GPU is much faster.
If you wanted to go AM4 (which is fine in my eyes, I just know that DDR5 is viable these days but AM5 is going to be expensive), I would build this
My basket at OcUK:
Total: £1,063.42 (includes delivery: £10.50)​
My basket at OcUK:
Thanks for this. Is the MB 5000 ready or will it require the BIOS update?​
