- 25 Mar 2004
- Fareham
Is that not true then? It makes sense to me that it is correct, and there would be enough juice left for 30 minutes more of use of the kettle.maybe the terminology is slightly wrong, but the gist of the calculations are right?
No, read above, a kw is a measure of current power usage, a kwh is the same but over time, for an hour.
If you use a kettle that draws 2kw for 2 hours, you will have used 4 kwh, not 4 kw.
