Am lucky i got a new fridge i can fit insidei should be able to last 30 seconds before i run out of air
Zoom in real close and you see it's a pair of themB52 up over Sweden, talk about roughing them up
Live Flight Tracker - Real-Time Flight Tracker Map | Flightradar24
View flight on Flightradar24www.flightradar24.com
Rumor 11 & 12You will be open to the Chinese.Goodbye, northern hemisphere. I'll be thinking of you down here in Australia!
As is the "Doomsday Plane" just outside Estonia https://www.flightradar24.com/RSD039/2d8c32ae
It was nice knowing everyone![]()
Not quite, Sun Tzu emigrated to Australia.You will be open to the Chinese.
So are the Media here . No one truly knows what’s going on
So just under 300,000 is ok then ?No, that's the full body count from all causes, including combatants.
The myth that 'millions have been killed' in Iraq needs to die. It's pure propaganda.
What you are reading is what you are told .You are this guy that does not know the facts and is all interested with feelings. Go and do some reading.
I know the Swedish elections didn’t go the way a lot of people hoped but that's a bit pre-emptive.B52 up over Sweden, talk about roughing them up
What you are writing is what you are told. It's rather obvious.What you are reading is what you are told .
Why I don’t agree with what is going in Ukraine sending billions of pounds in aid when the country is broke is a complete joke . This is not our war and we need to keep our noses out.
I’m reading exactly the same as you nd hearing the same as you . Nothing differentWhat you are writing is what you are told. It's rather obvious.
I note Communists think that the 'need to argue to defend' is democracies greatest weakness. It's our strength. It's called keepin your BS detector / Occams Razor sharp.
The entire world knew full well what hitler was doing and didn’t intervene fast enough .Yeah we should have left Hitler to it as well ....nice logic
What drum are you banging again?The entire world knows what Putin is doing and we're intervening. Where is the problem?The entire world knew full well what hitler was doing and didn’t intervene fast enough .
You wish.I’m reading exactly the same as you nd hearing the same as you . Nothing different
That’s a fact .You wish.
