I'm idly considering a whole new PC apart from drives and graphics card. My current PC has an i7-4790K (I've certainly had my money's worth from it), DDR3-2400, 600W PSU that's rather old now. My case is battered and broken (it came that way - I gambled on B-grade from here and lost). So I'm thinking that I may as well get a whole new PC and just move my drives and graphics card over.
I'm using Windows 10 and will probably continue to do so until it's EOL, so the Intel P+E cores CPUs aren't a good fit for me.
I probably won't be upgrading components in place. Building a PC from parts no longer appeals to me, nor does replacing the CPU with another (which entails most of building a PC from parts). If I upgrade again it will probably be a whole new PC again.
The most intensive thing I do on my PC is moderate gaming at 1440 and that's unlikely to change.
A medium-high AM4 spec PC is not that expensive now and would be much higher in performance than my current PC.
AM5 is significantly more expensive due to the higher cost of CPUs, motherboard and memory.
So I've been looking at AM4-based PCs with Ryzen 7 5700X or 5800X and 32GB of reasonably fast DDR4 and a reasonably good PSU with a reasonable good wattage and someone else building it for me...and they're quite reasonably priced.
But then I wonder if I'm daft buying a superseded platform. Then I wonder if I'd be daft to pay a fair bit more for extra performance I probably won't need and future upgradability I probably won't use.
