Permabanned
- 28 Nov 2003
- Shropshire
There used to be lots of working small bunkers for royal observer corps people, some come up for sale every so often, they're just basic fallout shelters.
Similarly, I think plenty of the civil defence shelters were essentially just fallout shelters for local council leaders etc.
It's not like most of this stuff is designed to survive a direct strike, if you live in a tall building in an area that doesn't get hit then the basement would be pretty good as would any core parts away form windows - gamma rays travel in straight lines so if you're mid way up a building in the core that means multiple layers of concrete to get through.
If you're in a house with a basement then a strong table down there with lots of heavy stuff on top would be useful, if you don't have a basement then lots of heavy stuff to the sides of the strong table would be needed too, like you could get a bunch of plastic containers filled up with water, bricks, sacks of earth, all sorts of stuff, seal up most air gaps in your house or at least the room you're going to stay in.
The basic principle, so long as you're not in an area directly affected by the blast, is to not breathe in contaminated radioactive dust and to get a whole load of solid mass between you and the gamma rays, at least for a couple of days and ideally for a couple of weeks... after a day or two you could probably move around inside your house to at least make a quick trip to use the loo etc. hopefully you still have some water supply but meh...
You probably have at least 30mins or so to put together an ad hoc shelter after a bomb drops. Obvs if there is a conventional war between Russia and NATO then it might be worth spending a couple of days getting some building supplies and trying to build a small shelter in the garden.
That YouTuber, Colin Furze could just become the most popular man on his road soon
