Is Overclocking dead in 7000 series?
14 Oct 2007
newcastle
I have just replaced my 5950x with a 7900x and it seems there is nothing to do as in overclocking as it boosted to 5.2ghz all core(88c) and 5.7ghz single core automatically, I was having a look in the bios and even though everything is on auto it seems everything is boosting as it should and there is nothing to play with
You can play with PBO and thermal limits :)
Overclocking days are pretty much a waste not worth it for everyday use they are pushed high out of the box with not much headroom
You can look at undervolting
Personally would tweak to reduce power / temps while matching or slightly beating stock performance
Got any hints for settings to use
There is plenty of tuning to do, check out the skatter bencher videos. More performance to be gained with PBO and curve optimiser.
Compared to the old days it's still there but in a different form. It's more about adjusting the limits and even undervolting since these chips are already so close to the limits.
I don’t know if I can do any better than the auto TBH, 5.120ghz all core in P95 holding at 95c drawing 210w seems pretty good
