Just been looking around and after deciding a month ago I wanted an R53 Cooper S purely because I used to want one, 2 weeks later its hurt my back & my neck, I'm not as young as I used to be, its sold!
Was looking around at something just comfortable, that won't struggle for space & get the job done, tbh I would have gone for a Focus kinda size but the spec/age for the same kinda money (2k-2500) is just scary in comparison to bigger cars.
Looking at a 2009 (59) Mondeo 2.0 TDCI Titanium X, seems to have every toy I'd want & need and more, economy OK & seems nice all ron from the viewing I had last week (Test drive at the weekend).
Its on 110K Miles, water pump & Cambelt done at 102K and while not complete, a very comprehensive service history, however, the down side, aroudn 1 month MOT left, and the following advisories from last year, would this be a walk away & don't be silly..?
Monitor and repair if necessary (advisories):
- Rear Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
- Rear Sub-frame corroded but not seriously weakened (5.3.3 (b) (i))
- Rear Subframe mounting prescribed area is corroded but not considered excessive (5.3.6 (a) (i))
- Nearside Front Suspension arm pin or bush worn but not resulting in excessive movement Trailing Arm (5.3.4 (a) (i))
- Offside Front Suspension arm pin or bush worn but not resulting in excessive movement Trailing Arm (5.3.4 (a) (i))
- Nearside Front Lower Suspension arm pin or bush worn but not resulting in excessive movement Front Bush (5.3.4 (a) (i))
- Nearside Front Suspension arm corroded but not seriously weakened (5.3.3 (b) (i))
- Offside Front Suspension arm corroded but not seriously weakened (5.3.3 (b) (i))
- Nearside Rear Suspension arm corroded but not seriously weakened (5.3.3 (b) (i))
- Offside Rear Suspension arm corroded but not seriously weakened (5.3.3 (b) (i))
- Nearside Front Noise From Suspension
