Why do people seriously do this?
Not sure hitting it at those kind of speeds is what the engineers at Land Rover had in mind when they calculated that.
Yep… 600mm steady entry not that, particularly when then intake air ducts are above the radiator. The amusing thing is they didn’t really buy that red Velar… it’s a management plate.
Good to see that kid still going - I caught a few of those vids in the first lockdown.
Must be making some decent pocket money with the millions of views each of his best weekly, best monthly, best of best fail video’s gets :p
It's strangely watchable when you're there and you kind of hope someone does screw it up for entertainment. If it's nice weather, the kids cheering them on when they accelerate just adds to the chance of failure :D
These videos always remind me of someone I know who did 15 grands worth of damage to a brand new Touareg on a flood road - after proclaiming it was what the vehicle was built for and gunning it in...
Sadly the wading depth on my Navara is only 450mm though unofficially it is fine for a bit more than that - but personally wouldn't be in a rush to put it through more than a foot or so.
He has nearly 27million channel views and Ben Gregers has over 60million views - probably made well into the 10s of thousands each - probably not £100+K as the estimation sites suggest.
What happens in these cases? Write-off/new engine with a claim on your insurance company?
Can't imagine everyone is paying thousands for a new engine out of their own pockets..
I can't imagine insurance will cover a lot of these as they'd be avoidable damage.
Isn't that what insurance is for? ¯\_(ツ)_/¯
What to know about avoidable and unavoidable flood damage​
Some insurers make a distinction between avoidable and unavoidable flood damage, and may not pay out for damage that they consider was avoidable.
Avoidable damage​
Avoidable damage is usually classed as such by an insurer if it was directly caused by an action you made.
For example, if a vehicle is damaged when it is driven through floodwater, this could be considered avoidable damage, and you may not be insured. A claim could also fail if you try to start a vehicle that is fully or partly submerged in floodwater.
Unavoidable damage​
Unavoidable damage to your car is usually that which may have happened regardless of your actions.
For example, while it’s advisable to move your car to higher ground if you believe a flood is on its way, it’s most likely to be classed as unavoidable damage if your car suffers flood damage while parked in its usual spot. In this instance, you would be covered by your insurance policy.
As ever, check the fine print of your car insurance policy if you are unsure.
They never learn.
Quite a staggering number of imbeciles been through the ford this weekend.
What would it "cost" them to turn round and go a different route?
I don't know the area but I'm guessing probably 5 minutes max.
Anyone tried it in an EV yet?
There have been a few model 3s going through it and they are fine. Well the number plate can be blasted off with enough speed.
Still you wouldn't want the water up to the base of the windscreen as the air con intake is near there, can't be a good thing for passengers.
The door seals are robust and there are various videos on the internet of Teslas doing fine in crazy deep water.
No idea why people are blasting through it anyhow, but the videos provided a little entertainment.
Problem with water into electrical systems is the failures can take time to develop aswell. The energy when you hit water is insane, crazy really.
Without anything to break the surface tension, beyond about 20mph you might as well drive in to a concrete barrier.
