Depends on the thickness of the pizza. Thicker pizza needs longer at a lower temp.Surely the correct method is to rotate it frequently enough / remove it before it burns, rather than turn the heat down
Thinner can be done full heat.
both I found it was better rotate and just turn the gas downSurely the correct method is to rotate it frequently enough / remove it before it burns, rather than turn the heat down
That is perfect. N'duja is the absolute best pizza topping.both I found it was better rotate and just turn the gas down![]()
What is your recipe & method for that perfect pizza above?N'duja is "the crack" for pizza lovers![]()
Poolish all the way !What is your recipe & method for that perfect pizza above?
Semolina all the way ! stops stickingI had a chance to buy Koda 16 for cheap but missed out on it so back to my Koda 12 again. Hopefully I have better luck with Pizza not sticking to the worktop and then to the peel.
Only just spotted your response, my apologies! Thank you for this, will give it a go."poolish"
150 gm water
150 gm 00 Flour
3gm yeast
3gm honey
Mix everything
then keep it for 1 hour at room temperature to activate
leavened it then put it in the fridge 16 to24 hours
To make the "pizza dough"
use all the poolish
add 350 gm water
then 625 gm flour
18 gm salt
mix leave for 30mins in bowl or the bench
then the fun part
olive oil your hands and lift from the middle and make a balloon
repeat 3-4 times and the dough will form fast into a round ball oily dough then rest 15min slice then ball up
if you need a vid https://www.youtube.com/watch?v=G-jPoROGHGE
Semolina as Mark says, and I also found that using olive oil in the dough makes it much stickier so I stopped doing that, just in case you are.I had a chance to buy Koda 16 for cheap but missed out on it so back to my Koda 12 again. Hopefully I have better luck with Pizza not sticking to the worktop and then to the peel.
I think I have tried that but will try again, we've got loads of Semolina.Semolina all the way ! stops sticking
Nvm. The Koda order has been cancelledSemolina as Mark says, and I also found that using olive oil in the dough makes it much stickier so I stopped doing that, just in case you are.
clearly they haven't seen vitos vidsI think I have tried that but will try again, we've got loads of Semolina.
Nvm. The Koda order has been cancelledI do use olive oil when making the dough, what I should I replace that with?
Olive oil in the dough works for a indoor normal oven on a stone or cast iron skillet like this .... that was done 280c+ temp on the pan ( cast iron pan ) then under a blazing hot grillInteresting idea to scratch the olive oil in the dough, I've been doing it habitually for many years ..
Poolish with honey? - can go the whole hog and build a sourdough starter - I prepare a poolish with 20% of the flour plus starter 24 hours/ambient before.
