- 21 Jan 2010
I'd just like to add that anyone who uses merged fields should be executed. Immediately.
I don't think that is unreasonable.
Cells. It's merged cells.I'd just like to add that anyone who uses merged fields should be executed. Immediately.
Maybe the Geeks have transcended; Who uses data in Excel in 2022 for anything other than Power Query?If I'd said it was a column on the left that I wanted on the right of the sheet, the thread would be a 20 pager by now.
The art of the Geek is dead here. Dead I tells ye.
*Hings heed in dispair*
I do (sort of), just in Power BI! I don't really use Excel for much other than connecting Forms data in SharePoint etc. to Power BI these days, everything else is via API or SQL work.You dont use Power Pivot? Its all essentially the same tools as you get with Power BI. I only discovered it around 2017 but static formulas and even VBA now are not used as much for this very reason.
Don't give me all that, Mister Miss Mrs They *delete as appropriate.Maybe the Geeks have transcended; Who uses data in Excel in 2022 for anything other than Power Query?
But did it solve the sandwich conundrum? I've forgotten now.Don't give me all that, Mister Miss Mrs They *delete as appropriate.
This was a basic formatting query, and this is the forum that famously settled the jumbo jet on a treadmill conundrum.
We need to get back to basics, kids. It's all ebbing away...![]()
I used to do a bit of vba and use macros quite a lot, but now I'm quite lucky in that most of my data sources have already been cleaned for me.I still see or work with people that use relic skills from ten or twenty years ago. Glad I taught myself some vba and the power tools at the time. There is so many tricks using all these apps and they can save you lots of time if you go looking!![]()
