- 20 Oct 2022
- Unite house
I have pre ordered for asus z790 hero motherboard. When can I expect the delivery for that?
Expo is the AMD equivalent or Xmp... I have not tried expo on Intel as its not built for the Intel imc and the spd is totally different.@8 Pack - Went ahead and purchased the Corsair Vengeance RGB EXPO 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (CMH32GX5M2B5600Z36). I'm assuming these will be plug and play with the settings above with an AM5 setup, will this mirror the same with an Intel setup?
I think those are due early next week. Already a couple of delays sadly. I can tell you that's a great choice our test boards are great.I have pre ordered for asus z790 hero motherboard. When can I expect the delivery for that?
@Gibbo Building an i9 system for a workmate, Will the i9-13900K have decent stock on the next delivery ?
Next week we’re expecting upto 500 units. I’d get your order in as the 13900k is selling very fast for us.![]()
Should work the same I'd thought? If compatibility proves an issue, I'll keep the memory for a future build as I was asked last night if I'd consider selling my current Intel combo.
Will it work? Most likely!
Do we recommend it? Nope.
Man you don't seem to understand our ethos.... We say something works if we physically tried it ourselves and only then... The internet, tech media is full of blah blah blah....I've just taken delivery of the memory and it appears my current platform may soon be up for sale. Overall... great build quality however I wonder what chips Corsair use for this memory and might it be pushed further? Anyway, that's for a different thread and cheers for the rapid delivery as always!
Z690 & B660 Intel Motherboards Will Be Fully Compatible With AMD EXPO DDR5 Memory Kits & Profiles - I recently found this article about compatibility with EXPO+XMP memory kits being used on either platform, looks like plug and play?
It wont always be the same cores boosting high on each 13900K...... The Bios detects the better cores on boot up and those are the Performance cores with the better boost ratio.Doesnt Matter buildzoid was messing in the bios and scrolled past it
I find it odd that its not
P Cores 58,58,57,56,55,55,55,55 or something like that
P Cores 58,58,55,55,55,55,55,55
E Cores 43,43,43,43,43,43,43,43,43,43,43,43,43,43,43,43
