I replaced the middle exhaust section and all 3 studs snapped with the nut on at the exhaust / manifold connection.
I removed the manifold and have drilled out the 3 studs to M6 size so far.
I'm now considering options. Firstly do these holes need to be tapped and secondly how bad would it be to just use M6 bolts and nuts instead of the original M8 bolts that were on it?
Ideally I would drill out to say 7.5mm and tap to 8mm (M8) then fit M8 bolts but at the moment I'm wondering if I can get away with just M6 bolts and no tapping?
