- 14 Jul 2005
- Birmingham
Hi all,
Im struggling to find a suitable TV unit for a corner position in my living room.
Issue 1 is I have a 55" TV which is 1228mm wide.
Issue 2 is that the corner it needs to go in is also close to a fireplace, so I can't fit in a normal TV corner unit - I need one with extra angles on the front side to miss the fireplace if I want enough width so that the TV is not overhanging the edges.
Issue 3 is the height. A 400mm high unit (which is quite low looking at the market) will have my TV at what seems like a considerable height in the room, over 1.2m.
See my sketchup drawings below, hope you get the idea of the problem.
Any one got any ideas?
