Permabanned
- 23 Apr 2014
- Hertfordshire
Same, just swapped it over, all up and running in 5-10 mins.
No need to ring them up, I plugged mine in and it booted up and did a software update. All working within 5 minutes.
What software update?
Make sure you don't put it off. I was going to do mine 'tomorrow', and a few days later our service died. No Internet, red ring around the SH4. The stats said online, but only on one downstream channel. I thought the DD must have failed somehow and they'd cut us off, but nope - and the stats confirmed Network Access: Allowed. Then I twigged... Plugged in the new SH5 and it booted and came online. I guess they set a self-destruct once your new hub is in the post.New H5 arrived today as they said it would, will get time later to install it and see if its wifi is better.
The hub will update itself once on the VM network for the first time.
Yes I think they blacklist the old device once its sent out. My brother had his Hub 5 delivered but hadn't had time to install it. They had a brief power cut and the old Hub 3 came up saying 'Notallowed' - swapping out for the Hub 5 then worked.Make sure you don't put it off. I was going to do mine 'tomorrow', and a few days later our service died. No Internet, red ring around the SH4. The stats said online, but only on one downstream channel. I thought the DD must have failed somehow and they'd cut us off, but nope - and the stats confirmed Network Access: Allowed. Then I twigged... Plugged in the new SH5 and it booted and came online. I guess they set a self-destruct once your new hub is in the post.
As for the WiFi, it's quite decent for what it is. Mine still got shoved straight into modem mode, but a quick out-of-the-box test beforehand showed 850Mbps down on an iPhone 13 Pro Max. Conversely, my Ruckus R710 enterprise AP (Wireless AC) managed 520Mbps.
Yea, just wanted the working day done first in case of any problems, its now in and am pleasantly surprised at how much better signal my docked laptop etc gets in the second room away now. Also set up my BQM a little while later so will see how it looks compared to the old one.Make sure you don't put it off. I was going to do mine 'tomorrow', and a few days later our service died. No Internet, red ring around the SH4. The stats said online, but only on one downstream channel. I thought the DD must have failed somehow and they'd cut us off, but nope - and the stats confirmed Network Access: Allowed. Then I twigged... Plugged in the new SH5 and it booted and came online. I guess they set a self-destruct once your new hub is in the post.
Here's my before and after TBB plots with the header (and my WAN IP) cropped off. Bear in mind these are both in modem mode, with an x86 edge router.
The outgoing Hub 4 (Puma6):
The new Hub 5 (Broadcom):
I'm running a Tor relay, amongst a dozen other servers, so my latency actually appears worse than it is. I have ICMP on low priority to not interfere with the server traffic. Quite a nice improvement, though obviously still a far cry from FTTP.
It can.Can anyone confirm if using the HUB 5 in modem mode if the 2.5Gbps port can be used to provide the link to another router that has a 2.5Gbps port?
Good to know, cheers.I have not had any issues. However we dont really have "lots" of devices. Maybe 20 wifi enabled devices tops.
With VM it is simple folly to assume anything!Hello All,
I'm getting Virgin installed in a couple of weeks, it's 1Gig so assume it'll be the Hub 5 from the off...
I just had a new 1Gig connection and they sent a Hub4! If I were you I would call them up, speak to someone in a British call centre and stipulate you want a Hub5. If they confirm you will get one, get the name and team of the person you are speaking to and record the time. (I record all my conversations with VM)
Then cross your fingers and pray when you open that box is not the square shaped top of the SH4!
