Whilst I'd like a proper compressor, I don't really have to space to justify one just for pumping up tyres. And as the car is parked outside on the road, I'd have to drag it out to the path and get an extension lead for it. Also handy when my girlfriend drags me to her the stables to give the horsebox she uses once in a blue moon a check over. So I thought a portable one that runs off batteries I already have would be a good replacement for a footpump. As for accuracy, I have a separate pressure gauge, so I always tend to overinflate a few PSI, then use that to let the tyre down until it shows the correct pressure, just in case.
Unfortunately, the Makita one that was mentioned earlier, that I then found on ebay, turned out to be a misleading advert, and they sent me a cheap Chinese copy. They refunded me no quibble, but I'm still pump-less atm
