Man of Honour
- 5 Jun 2003
- Falling...
Ultimately even with a tiny bit of generation you're still spending less on electricity. Marginal gains are better than losses.
I've just helped a friend of a friend install his two cheapo second hand 240w panels, with a grid-tie micro inverter, straight into the 3-pin basically, and he's over the moon with the results already, the panel mounts can he adjust for different angles and they are just sat on his patio for now pointed as south as they can be with no shading. Spent less that £400 for everything, including a waterproof socket etc. Payback time in less than 12 months, and now he's looking at getting a small 12v battery setup.![]()
Tell your friend to get one of these, plug the inverter into it before the wall socket.....it will read the energy produced via solar in Watts/going into the ring.
Great thanks. Those we're the ones I had seen on amazon. Good to know they aren't junk.
Is there an amount of generation you're allowed to do beforeyou haveyou're supposed to inform the DNO?
333kWh here for October.
21st to the 31st of October with the new inverter fitted =60.4kWh.
Sunnier than Kent..
