Solar panels and battery - any real world recommendations?
Ultimately even with a tiny bit of generation you're still spending less on electricity. Marginal gains are better than losses.
I've just helped a friend of a friend install his two cheapo second hand 240w panels, with a grid-tie micro inverter, straight into the 3-pin basically, and he's over the moon with the results already, the panel mounts can he adjust for different angles and they are just sat on his patio for now pointed as south as they can be with no shading. Spent less that £400 for everything, including a waterproof socket etc. Payback time in less than 12 months, and now he's looking at getting a small 12v battery setup. :cry: :D
Can you link to the Inverter you used please?
I think sticking a few panels on the shed to cover base use is better than paying over the odds for a proper setup right now.
And that is exactly how I started out 5-6 years ago, now I have a homebuilt system with 1.5kw solar with 17kWh of Lifepo4 batteries, all from small beginnings :D
Tell your friend to get one of these, plug the inverter into it before the wall socket.....it will read the energy produced via solar in Watts/going into the ring.
Great thanks. Those we're the ones I had seen on amazon. Good to know they aren't junk.
We'll see in a few months, although he only paid £88 with a discount voucher so it was worth a punt, and the panels we £35 each. Spent more on cables, and mounting than actual generating equipment.
Is there an amount of generation you're allowed to do before you have you're supposed to inform the DNO?
If its grid tied I think I saw something just under 1kw is the point you need to notify
Edit : Looking again I am not so sure now. I think it still needs notifying but they make some claims about not needing to complete other data that larger installs need.
Maybe something changed
255kwh in October for us.
We get shading this time of year it seems, more or less from the start of October which reduces generation quite a bit until about 11am (before the clocks changed) but it is what it is.
Still thinking about putting some more panels up myself but may leave it until spring now, mainly as I want the weather to be better working outside :)
We got 280 units from our panels in October that we were able to use (saving £91.84), 354 including what was sent to the grid.
21st to the 31st of October with the new inverter fitted =60.4kWh.
Where abouts are you based? I suppose it also depends on your system and your orientation.
I'm lucky that I got nearly double yours in that same time span but I guess that's the advantage of being 20 miles from the south coast.
