I use one screen at a time mate thank you for the reply.Basic things first, are both screens plugged in at the same time? Check that you have set the output to go to TV AND monitor, not one or the other.
Is the PC detecting the TV as a monitor, but the TV just not showing a picture? Might simply need to change the AV channel on the TV.
Thank you for the reply how do you get this up on the tv?have you tried device connector in settings, i have lg tv and had to change it to pc to give me output to tv
No 4090Not a 4090 by any chance?
not all LG tv the same, but mine is in settings and connections. there could be various reasons, many listed above. i thought i had same issue and bought a DP to hdmi adapter, but found my issue , which was i needed to set it to pc to detect the signalT
Thank you .not all LG tv the same, but mine is in settings and connections. there could be various reasons, many listed above. i thought i had same issue and bought a DP to hdmi adapter, but found my issue in en which was i needed to set it to pc to detect the signal
I tried my pc on the daughters samsung flawless not a problem. Tried factory restore still no display .on my TV . I'm lost might buy a hisense 4k .
