- 24 Apr 2007
- Southport
You lucky duck! 13.9 without heating in NW EnglandHouse is still between 20 and 22 without heating and in the south. Heating will not be going on yet!
50w. My mobo allows power draw from usb when off and I also have an amp, dac and eq on my desk.How much were your computers pulling when off?
Yea I'm not gloating but felt like I had to say itYou lucky duck! 13.9 without heating in NW England
our heating came on this morning properly (as in for an HR or so) (near Cambridge). I think it had popped in for 15 mins a few times over the last week but this was the proper time it was on long enough for the upstairs rads to get hot . the lounge is toastie warm now without heating but Christ the converted conservatory / dining room is cold. for the next few months meals will be at the breakfast bar in the kitchen or on our knees in the lounge unless it is a special occasion. no point heating it just for the 3 of us.You lucky duck! 13.9 without heating in NW England
You must have a glasshouse effect, very clever if done right all the insulation must be dead on. My relatives from Scotland said they feel the south is kinda tropical comparativelyHouse is still between 20 and 22 without heating and in the south. Heating will not be going on yet!
Have you checked to see if you're roof's still on?I don't know how that's possible,
Been away 3 days and the house is same as outside. 12c in one room
4 of us in newish 3 bed house, semi detached down south.I don't know how that's possible,
Its amazing. We are in Cardiff. So not exactly North! Heating has been on a lot last week and a half4 of us in newish 3 bed house, semi detached down south.
No option to just time the emersion heater for one hour, if you're on storage heaters the immersion usually has a timer function.
You can only set to ON, the current time that it is now, and boost.A conservatory should always have doors to seal it off in the cold, all these conversions that join a conservatory into a wider open living space just cause massive heat loss. Saw a few houses that had done this and it instantly put me off as its obvious that it will cause issues in Winter.our heating came on this morning properly (as in for an HR or so) (near Cambridge). I think it had popped in for 15 mins a few times over the last week but this was the proper time it was on long enough for the upstairs rads to get hot . the lounge is toastie warm now without heating but Christ the converted conservatory / dining room is cold. for the next few months meals will be at the breakfast bar in the kitchen or on our knees in the lounge unless it is a special occasion. no point heating it just for the 3 of us.
New builds are fantastic for insulation.
I had all the windows open for about 2 hours yesterday while I worked in the house (gives it a good airing too) and the temp dropped to 13.5oC on the Nest.
Closed all the windows as I was leaving house and, without any heating on and no one home, it rose to 16oC after about 2 hours.
I have a South facing patio door so I can leave the internal kitchen door open to rest of house and let the sun warm the house just from the sun coming through the patio door glass.
Even when I am home, the temp increases just from my own body heat.
ours is a converted conservatory with a light weight proper roof with lots of insulation. it is far warmer now (it leaks but that is an issue in another thread) but this room IS our dining room and we still have the old patio door on it to shut it off from the kitchen when it is too cold. it's warmer today and we are back in there now. having 5 people in there helps heat it.A conservatory should always have doors to seal it off in the cold, all these conversions that join a conservatory into a wider open living space just cause massive heat loss. Saw a few houses that had done this and it instantly put me off as its obvious that it will cause issues in Winter.
Joining them to a kitchen seems to be the most common, at least you can shut your dining room off.
just put on an additional layer ... but agree they could form the basis of a good heated mouse mat to keep typing hands warm wfh - or, moreover the plant pot/propagation onesThis is a game changer for trying to keep warm.
It's a 'vivarium heating mat' meant for keeping reptiles warm. Put it between your jumper and outer layer and it's a mini radiator for your core. It also creates a little warm updraft for your face. Plus it's only 14w, and only £15.
have you worked out what you should/could be using form expected U's VNew builds are fantastic for insulation.
