- 21 Jul 2005
- Officially least sunny location -Ronskistats
Will a high end ampere or 7900 not drive this monitor?
@SpellowHouse keep the monitor. What is your current GPU?
I have a 3070ti. I'm tempted in to buying the new AW3423DW!! I had the intention of replacing it with a 4080 this year but that plan seems to be cancelled now.
3070ti should be ok at that res. especially with dlss, obviously a couple of settings may have to be turned down though in the more demanding titles, depends what fps you're happy with!
I can recommend the qd oled monitor though, the display is always the most important thing imo and being oled, nothing can match the iq, motion clarity you will gain.
It is in most games, but it struggles in some. DLSS is a life saver, it's true. Or, failing that, NIS is really good too.
Yep, the AW3432DW looks really nice. It was not a planned purchase at all, and if NVIDIA hadn't messed up the 4080 I would probably have waited until they brought out a AW3822DW!!! But now I am really not sure what to do.
Might be worthwhile checking out the freesync version of the aw monitor too, slightly less specs (not enough of a difference and the gsync module isn't really beneficial on oled) but a fair bit cheaper.
I would sit tight on the gpu front, 7900xtx looks good though if you don't mind the 1+k price or maybe Nvidia might drop prices once ampere stock has dried up or the 7900xtx forces their hand....
I never really understood why G-Sync is not really beneficial with oled?
At this point we’d usually point out the advantages of the G-SYNC module in terms of supporting variable overdrive, re-tuning the acceleration across the refresh rate range to prevent strong overshoot at lower refresh rates. For OLED models aggressive pixel overdrive is not required and overshoot isn’t an issue either way.
I have a 3070ti. I'm tempted in to buying the new AW3423DW!! But even that, well, there aren't many HDR games around. I had the intention of replacing my gpu with a 4080 this year but that plan seems to be cancelled now.
Just to add to that list of ones I've played with hdr of the top of my head
Horizon zero dawn
Riftbreaker
Gears of war
Mass effect legendary series
Guardians of the galaxy
Metro ee
Rdr 2
Days gone
Doom eternal
Would it not be good idea to wait monitors with dp2.1 to come out in the new year. I'm looking to go ultra wide 1440p and need gpu for that.I have a 3070ti. I'm tempted in to buying the new AW3423DW!! But even that, well, there aren't many HDR games around. I had the intention of replacing my gpu with a 4080 this year but that plan seems to be cancelled now.
