- 19 Feb 2007
- Sol
Want to tweak my memory and was wondering if anyone knew the max safe voltage for DDR4 Micron equipped modules ? I've looked around but found a lot of contradictory information.
There are several Micron chips used in DDR4, any idea which yours is?
According to Thaiphoon it's Micron E-Die which others have said is good for daily use at 1.45 but others have said 1.40v, So much contradictory info out there.
Depends on the IC, 8gbit rev e and 16gbit rev B can happily take over 1.55V however for the other ICs I wouldnt go over 1.35 vdimm.Want to tweak my memory and was wondering if anyone knew the max safe voltage for DDR4 Micron equipped modules ? I've looked around but found a lot of contradictory information.
1.5 is absolutely safe and fine for Micron Rev E, with up to 1.55v being fineI would recommend not going more than 1.4V. it is important to note that 1.5v is the maximum safe voltage and that running your modules at this voltage may cause them to become unstable or even fail.
based on info collected from friends who have ran their Rev E at 1.55 to 1.6v for the past 1-2 years with no degredation, and others in OC community who have been overclocking it since it came to market in 2017/2018.based on what info?
