- 14 Jul 2005
- Birmingham
Hi all,
Bay window in bedroom is a square shape, windows on two sides.
Width 2.4m on the large window, 0.6m on the small end side.
As you can see there is not any space above the window, its straight onto a bay window ceiling which has a batten fitted to it.
Anyone know of any good solutions whereby I might be able to fit both a blind close to the window and then have some curtains too, or are we resigned to blinds only on this? I looked at the perfect fit blinds which attach to the window frames but they are expensive because you need one per pane of window.
